Ported vmp gen3, dob gen 2, ultra level 4.63v stroker, built 6r80 swap bout to handle business
sportinawoody
Piedmont area , N.C.
I run 1” lines with no restrictions and a Stewart emp pump. Detonation is not an issue. By the time I come down the return road at my track my iat’s are already back down to 120* and dropping
sportinawoody
FINALLY !!! Quick update. Got my tune dialed. Pretty damn safe. Had to fix some belt issues but here’s the run down and results on low boost and a video. 100% pure 93 gas no additive or 110, no meth, no ice, 16psi until right where power fell off and hit 17psi, 17* total, he drops my afr in at 11.7 and by 6k it’s at 11.0 so there is still alot ( maybe 50ish)on the table between the fuel and another degree or 2. Pulled to 7k. Iat topped out at 117. Final numbers on this were 720/612 but what’s more impressive is the hp curve. Don’t mind the tire spin. Dual bearing idlers are a must before I can go back to try an make 1k on the 2.5” pulley.
DieHarder
Impressive, I have a DOB setup (Gen 2) as well. Don't have a built bottom end though. By chance can you tell me what the short block cost you and what the turn around was?
sportinawoody
I built this shortblock 7 years ago so cost was absorbed then. This go round was a refresh with new pistons but I also had the block sleeved. Was around 6k this time. I run coated custom specs diamond pistons, Oliver rods, etc,,,
