Power seat woes - any quick way to test the switch
06roush
Power seat lost the function to move forward and back. I want to hope its just the switch and not the motor. Can anyone explain if i have the switch out of the car if i can test the leads with a voltage meeter?
01yellerCobra
San Diego, CA
You'd need to know to pin out so you which pins are shorted together for which switch position.
Same thing happened to our 06. Swapped out the switch and all was good
Misspelling brought to you by Tapatalk
irishpwr46
Official Site Vandal
NYC
you should be able to, im not very knowledgeable as far as voltage meters, but i do know that theres a setting to test for continuity. if you put one lead on the power in, and then the other on the output from the switch, it should get a reading when you activate the switch. test it on the ones you know work and it will tell you if the others arent
RedGt
Europe
Had same problem,you can take the switch apart.Maybe there is a bad contact inside.
RedGT
06roush
got a new switch, that was it.
Thanks for the help guys
