Kaldar142
I wouldn't bother with the windage tray or crank scraper right now.
Whys that?
Do you think running 100 octane at the track would be any benefit? I don't mind paying the extra $$$ if it will help keep my car just a bit safer.
just so i understand, why exactly is the cowl area a high pressure zone? what does that mean lol
I have a buddy that works at a local Ford dealer. He told me to only run 87 octane unless I have an aftermarket tune. I am guessing that you guys have some sort of programmer to run higher octane? Also is the 100 octane you use in your car unleaded?
The simple answer is yes I have a tune for racing. We tuned with 93 in the tank but I routinely run 100 unleaded at the track. If you run leaded fuel you'll damage the cats and over time possibly valves. My car is supercharged and makes 535 rwhp but that's not really the issue.
Been doing a lot a reading lately on dyno tuning for cars being used in road racing (Porsche forums) and spent a little time with my tuner, who is arguably one of the best drag race tuners around, to get a solid road race tune down. Drag racing is somewhat easy as it takes 10 seconds or so of extreme conditions and it's over. You'll spend 20-30 minutes in the average DE event and exposing the fuel and lube systems to significant g's all of which can't be seen on the dyno. At some point during the run, there will be a leaner condition which will pull timing out of your car to prevent detonation (detonation=heat).
The higher octane will keep the timing up longer and help prevent the lean condition.
waist of money
I wish I had a waist of money.
I think I know what you were getting at, but there are some things that I would consider inaccurate above... G-forces on the lube system will have little measurable effect (on an instantaneous basis) on combustion chamber temps. G-forces on the fuel absolutely CAN and WILL at some point cause a momentary sag in fuel pressure, and thus in fuel delivered to the injectors. That will cause a lean condition. The car's computer will have to pull timing at that point to reduce combustion chamber temps to avoid pre-ignition (detonation). Simply changing the type of fuel, up to a higher-octane type, will NOT affect the mechanics that govern fuel delivery. Higher octane fuels, in a nutshell, effectively detonate at a higher temprature (pressure), allowing for more timing to be run prior to detonation. More timing=more power. The type of fuel used will NOT "help prevent the lean condition," which is a mechanical function, and the main cause of detonation. If you tune for less power, running richer and with less timing, then you'll have a safety margin against detonation, but if the pumps suck air, you're going to go too lean, no matter what kind of fuel you are using.
My understanding of the physics involved with higher-octane fuels is that the fuel itself burns cooler and has a slower flame-front propagation rate than the pump gas does, and that more timing can be dialled in to allow you to extract the extra energy potential of the higher octane fuel. Either way, if your tune is on the edge, if you sag the rail pressure, then you'll wind up detonating.
Bottom line: For the road course, run the fuel the car was tuned for, and set the tune up conservatively. We've ALL experienced fuel slosh, whether we've realized it or not. How many times have we been on track with around a half-tank (or less) of fuel, and watched the fuel gauge cycle back and forth between full and empty? That's fuel sloshing from one side of the saddlebag tank to the other. There is a "transfer pump" of sorts that's supposed to equalize the two sides, but it was never designed to keep up with the constant cornering forces we expose our cars to out on track. The only way to really guard agains a slosh-related lean dropout in rail pressure (with a stock tank) is to run the tank at least 1/2 full the whole time we're on track.
Just a opinion but the oil pan is a waste of money. I've talked at great length with people in the fr500s program. not needed. no fr500s cars have pans on them and they ran fr500s cars at the 25 thunderhill with stock pans. I run a stock pan and I Have not seen anything that would make me believe it's needed.
Don't believe all the hype that it is a must need.
side note: does the roush trak- pak come with a road race pan ?
I've been running the piss out of, and pulling way over 1g (1.2 not abnormal considering I can pull 1 in a slalom) for 3 years in an S197 with no issues. Can't say that there might not a split second here or there the sump isn't uncovered, but certainly oil 'starvation' hasn't been an issue, and if the FR500S's are using a stock pan, I think that's about case closed on needing to upgrade it.
