Procharger P1SC H.O. kit for 2005-09 GT
Status
Not open for further replies.
hotrod_renegade
Captain Hindsight
MANtana
Up for sale I have a Procharger P1SC H.O. Supercharger kit for 2005-09 Mustang GT. I bought it used from another member on this forum few years ago as a tuner kit and pieced the rest together myself. It actually has a 12-rib pulley setup, which is a little overkill for this system but that’s how it came when I bought it and it works. Comes with two supercharger pulleys: 3.33” (12-13 lbs. boost) and 4.25” (7-8 lbs. boost). I personally ran the 4.25" pulley, which was good for ~7 lbs. in 5300' of air. Also included is an ATI Superdamper which is required for the 12-rib crank pulley and a Procharger slim fan which I had to use to make room for the 12 rib setup. I have a new 12-rib 70" belt and BOV filter on order from Procharger, which are not in the pics but will be included with the sale. Asking $3500 + shipping.
Included:
- Procharger P1SC H.O. 12-rib tuner Kit
- Ford Racing 47 lb./hr. injectors
- Kenne Bell 20 amp Boost-a-pump with S&H fuel pump wiring upgrade kit
- Diablosport MAFia MAF extender
- Procharger Slim fan
- ATI superdamper
- Autolite HT0 Spark Plugs (brand new, gapped at .030, 1 heat range colder than stock)
Things you will need to make this setup complete:
- Cooling system upgrade kit for 2005-06 cars
- Aftermarket coolant reservoir and relocate power steering reservoir (or, if you're a cheapass like me you can just zip tie them off to the slim fan)
- ARP Damper bolt for the ATI balancer (part# ARP-156-2501, $28.49 from Summit). The stock bolt cannot be used with this damper.
- Tuner and a tune
A few other notes:
- The finish on the piping is not perfect, there are scratches and scrapes. A good powdercoating would make them look nice if you are picky about appearance.
- The intercooler does have a few dents in the fins on the front sides from being mounted. It was like this when I bought it, and does not affect the performance of the intercooler. Can be seen in pics below.
- The outer shoulder of the 4.25" blower pulley is dented in on one side. It was like this when I bought it. I ran it like this for 3 years and had no issues with it on the belt. Can be seen in pics below.
- The underside of the tensioner is scratched up a bit due to me having it set incorrectly and the belt rubbing on it when I first installed it. It's not noticable once it's installed as it's on underside of the tensioner.
- The I.D. tag on the blower is faded, but the serial # is still visible. Can be seen in pics below.
None of those affect the way the kit performs, but they are there and I felt they needed to be pointed out.
Not interested in parting any of this stuff out right now. If the kit doesn't sell within a month or so and there is interest in the other parts I'll open it all up to sell individually.
hotrod_renegade
Captain Hindsight
MANtana
I never had it dyno'd. I had a lot other mods (long tube headers, Ford racing cams, etc.) and it was remote tuned by Lito so I'm just guessing around 420rwhp or so. I think the 3.33 would put you pretty close to 500rwhp with everything else stock, that may be pushing it on the stock bottom end. I went the safer route.
05stroker
Never enough power guy!
Bullard Tx.
Back when I had a P1 and a stock block with long tube headers a 4.25 pulley made 10 pounds of boost and 450 horsepower. I then stepped up to a 3.75 pulley and made 12 pounds of boost at 500 horsepower. GOP here is losing a little bit of boost and power because of the hot rod cams I would have seen
hotrod_renegade
Captain Hindsight
MANtana
There is probably a lot of truth to this. I read on here the hotrods weren't the best for boost as well, but I had already previously installed them so I just left them in. I'm also in about 5400' of air so that wasn't helping any either. My rwhp numbers were just a guess, so don't read too much into that. But the boost numbers are what I saw with that setup.
05stroker
Bullard Tx.
Yea, your DA sucks! Good luck with the sale, I have passed it to a few guys. Sounds like it's priced right.
hotrod_renegade
Captain Hindsight
MANtana
Thanks. I think it's a good setup for someone who is stock now and then if they decide to build the bottom end all they'll have to do is switch to the smaller pulley. That was my plan anyway, but I ended up selling the car before I made it that far.
13726548
GA
If someone is buying this and needs a base tune to get the car running, I have a Diablo Predator u7140 for a 4.13" pulley setup. It comes with a preloaded tune from Procharger.
Asking $180 shipped.
Status
