Procharger P1SC Stage II Kit Install PICS/VIDS
8WOOD
Pensacola, Florida
BV600 what part of Florida are you from? It would be interesting to race our mustangs at a track @ same boost level and timings and AFR and see if there is much difference between P1SC and D1SC. Just saying.
8WOOD
Pensacola, Florida
Hey everyone, I ordered a lethal X pipe that will be here tomorrow. Maybe you can help me figure this out.
Right now I have cats on the car and at idle and cruising my AFR read 13.85-14.25 which is where the command rate is set to. This seems extremely rich to me because on my turbo evo's without cats I'd run 14.7 AFR. Is this a normal AFR for these mustangs with cats?
Twinscrewgt
Bad Smurf
Ogden, Utah
Stoich is no Lonfer 14.7 because of the 10% ethonal. It's more like 14.3 if I recall. So you're running just about right
BV600
TEXAS
Im from Daytona Area, but Im in Germany until july. I would meet up if I was there
tagle281
Corpus Christi TX
For those of you using prochargers, will the kit for the stock intake work on a car with a Boss intake? Or is there something else needed?
zemog255
Custom User Title
Where everything is bigger
The one that comes with the procharger kit will work fine with the Boss intake. Not my car Im not sure if he is a member on here or not.
tagle281
Corpus Christi TX
Does the stage ll come with intercooler upper and lower deflectors? My tuner kit came with some but they aren't in the inventory or instructions. I've called Procharger a few times but I will just say their tech line is lackluster IMHO. I can't get a straight answer from them.
