BAKnBLK2010
Harley Davidson FLHTCI
He's using the 19" tires in his example.
The 19's are 27" tall also so it doesn't make a difference.
I just bought a SCT programmer and CAI from American Muscle. On the race tune 93, I noticed the rev limiter is set to 7,600 rpm.
This seems high to me. Probably because I'm just not used to the high revs. I shifted at 7,300 and the car was still pulling hard. Totally woke the car up. Unbelievable.
What RPM will these motors go to safely? I'm thinking of kicking it down to 7,200.
But he also had a blower that caused the detonation. 7500rpm n/a seems to be ok, at least thus far.Beefcake had detonation @ 7500.....
Yeah, 7500 is safe rpm from what I've been reading....from what I have picked up in this thread there are a few that are running 8000+
That's absolutely correct. The Brembo brake package and P255/40R19 tire. Didn't bother to look up the exact diameter but my program puts it as 27.03 tire diameter. Really doesn't matter if it's off a bit this way or a bit that way as the shift points remain the same.
Need a tiny but of help.
In the process of selling a 370z and on the fence regarding getting a Boss or doing my own thing on a regular 5.0. The factory rev limit on the Boss is 7500 rpm and the promo's I've seem list forged rods. Are the bottom ends the same? If so, it's kinda a no brainer for me.
im gonna have to try that next time i get out to the track. It just seems so weird to be shifting at different points each time. I figured you would shift at the same spot due to the power band being the same in each gear?
Sorry if its a dumb question, ive just never gotten into the specifics of where to shift when drag racing before.
i may be dumb....but my how are you getting to 122mph at 7200rpms in 4th gear? I trap at 115@7300ish with the 3.73s, which was the gear ratio used.
Keep in mind, that trap speed is not your speed at the end of the quarter. It's the average mph your car reached over the last 60' of the track. You're going faster at the end of the quarter.
EDIT: My bad, looks like you're right.The Boss has the same steel crank, but gets better rods and pistons.
If you guys havent used it yet, the two step feature works great too in the SCT tunes.
How does this work? I read about it once but can't seem to find it again. I think it uses the buttons on the steering wheel to set the launch rpm. How does it activate, brake or what? How does it turn off when you launch? Who does their tunes with this feature? Sounds really cool.
The Boss rods are better but they are still forged using powder forging.
