Roush TVS 2300 Phase 2 Dual belt 05-09 SC kit 421103
JimIII@JDM
$6000 + S&H
This is a Brand New, never used Roush TVS 2300 Phase 2 Dual Belt Supercharger kit for a 2005-2009 Ford Mustang GT 4.6L 3V. This kit was opened and had some parts removed but have been replaced. Some extra hardware will be included (Bolts, Nuts, Studs,etc) Includes printed out instructions. Also the Heat exchanger is the updated 2010 Version, we included extra hoses for fitment.
This supercharger kit requires custom tuning, it will support up to 700 HP with a properly built engine and good custom tune. On a Stock 4.6L 3V engine approximately 550 HP is the most safest output. Contact JDM Engineering for custom tuning support.
Components are separated in boxes at the moment and shipping time will take approximately 1 week to package everything together. Note entire kit is not pictured below, intake manifold throttle body, fuel rails, and more are included.
This kit Retails for $7499.00 Brand New, buy this kit now for a big discount!
Roush's Website description:
This Mustang GT Supercharger Kit is engineered for the 2005-2009 models and brings your car's total power to an impressive 550 hp and 500 lb-ft at the flywheel.
Below is a list of the components included in the supercharger kit for the Mustang GT. :
TVS2300 supercharger
Induction system
89mm bolt-on pulley
Fuel charging assembly
Intercooler
Wiring
GT500 fuel system upgrade (If you already have a GT500 Fuel system or other upgrade we can delete from the kit)
This Mustang GT Supercharger Kit is part of an innovative line of upgradable ROUSH superchargers kits for Mustang GT's -- allowing you to build up power at your own pace. This "phased" supercharger line includes two different FEAD systems. The single belt FEAD kits are comparatively less expensive than dual belt counterparts. However, the dual belt systems allow for improved management of power. This can help particularly in high horsepower applications.
***NOTE we can remove Fuel injectors, Throttle body, Air intake, Cooling Components, Fuel system, or Heat exchanger if you have other parts you want to use. Let us know what you are looking to do and we can discuss options.
Vcfire2299
New York
what would be the price of this kit if i did not want the gt500 fuel pump? possibly interested in this for my 09 gt
JimIII@JDM
I can do it for $5400 with out the fuel pump assembly. It is going to require one based on the pulley combination. You will see about 11-12 psi boost and make close to 500 RWHP with this setup.
JimIII
Vcfire2299
New York
wasn't able to make the deal and had to back out because i am about to move and can't swing that money right now. but this is a fantastic deal so if you have a 3v and wanna boost, go for it. i can vouch that jim as well as his team at JDM are fantastic and go out of their way to try to help you. if you can swing the money, go for it, you wont regret it!
