This do it yourself kit is for guys wanting to install one of these pumps on their own hat and to save some down time and $.
The AEM 50-1000 is the most reliable and proven 340lph pump out there, it flows 342lph at 13.5V/39.15psi. This cost effective kit will support 500hp depending on injectors size and setup as it sits and more with a bap.
Kit includes:
-S&H Fuel sytem wire upgrade kit
-New AEM 320 pump (340lph)
-Walbro high flow filter sock (e85 compatible)
-Gates submersible 30r10 3/8" fuel hose
-2 Stainless steel fuel injection hose clamps
-10 gauge power and ground wires with terminals for the pump
-Ziptie
This kit has everything that I use to install one of these pump on the stock hat. I also have directions with pics to email to help walk you through modifying your stock hat to fit this pump and install the wire kit.
$179 with free shipping in the cont us.
Wire kit
Pump and install kit
Looking for a cost effective fuel system to run some corn on your stock block setup. I can also do the kit with the AEM-E 15-1200 340lph pump (e85 safe version) for $15 more.
Kit includes:
-Ziptie
Wire kit
