bcb06gt
Guys, I am in the middle of installing a Saleen SC on my car and seem to have "misplaced" the nut that goes on the boost control valve stem that comes out of the supercharger on the passenger rear. The nut basically secures the silver metal piece on the boost actuator. Does anyone know the size? The actuator was removed to make the rear bolt easy.
Other than that, install is going well. A little time consuming but well. I have the SC installed, crossover, heat exchanger, water pump. Remaining is fuel rails/injectors, splicing alternator sensor (?) and air intake temp, tb and intake tube, vacuum lines, water pump relay, refill coolants.
Any tips on the coolant refills (supercharging system and engine cooling)?
Thanks
Bryan
Thanks
Bryan
