- Joined
- Apr 6, 2007
- Posts
- 373
- Reaction score
- 1
alrighty then techies. I just had a Saleen series VI installed, changed pullies etc etc....at what point is it wise for me to change the fuel pump, when should I have to....right now..with my saleen i changed to the 39lb injectors, FRRP cold plugs, 90mm lightning MAF, kooks L/T with catted x pipe, that Intake boot is the saleen extreme one....and I have a C&L Conical filter and heat shroud on the end....it is an Automatic GT with stock gears: so with that out of the way....I was going to switch to the 3.4 pulley but was concerned that 9.5-10PSI was too much with stock fuel pump so I got the 3.6 with 7.5-8psi.
will there be any gains to switch the fuel pumps or is it simpley peace of mind and safety factors. am I okay with my stock pump and 7.5-8psi boost....what should my fuel pressure maintain at (so I know when I am looking at the gaugewhen am i running into danger) sorry for the NOOB questions....just wanting to see some STRAIGHT ANSWERS that are not SALES driven as if you ask a vendor them...
TJ
TJ
