HellsBells
620/677
Hey everyone,
So my tuning problems are never ending. I am retuning the car for 91 octane down from 93 octane. My question really homes in on timing and I am at a loss.
Here are my motor mods relevant to tuning:
Here is the most power it made with 16 degrees of timing up top, on 93 Octane with methanol:
(Ignore the dip up top, you can see it went fat there and then picked up. This never showed up again after we tuned it out)
As you can see the chart is a bit shaky, especially up top--my other pulls from yesterday were much worse and across the entire powerband.
Here's what we did on 91:
Retuned it, AFR's are dead flat 12:1 (i mean, DEAD FLAT) but the hp graph was zig zag up and down through the entire pull. This car has never made a clean smooth line ever since the new motor.
Yesterday, we were putting down anywhere between 540hp/600tq. We were wondering where all the power went. The strangest part was that while horsepower was down, torque seemed to still be fine. SAE correction on/off showed little difference.
So against better judgment, decided to throw more timing at it, especially down low. Ran 4 degrees on the bottom end and put it to 23 degrees up top--leaned it out to 12.5 AFRs. Sure as shit, car made 581/640 on 91 and meth--but the most confusing part was that the graph was the cleanest pull I've ever seen. I always have smoothing set to 0, and this graph was really straight, no wiggling up and down. It was even smoother than my mostly stock pull, which was fairly smooth (I forgot to print out the last 581/640 pull):
So now my dilemma is, I am definitely not making the power I think I can make, but can I throw more timing at it? I can't figure out if leaning out the AFR's made the graph real nice and smooth or adding the timing did. That will have to wait until next time I get a chance to experiment.
In a nutshell, the hp/tq graphs are telling me that the car wants more timing or wants to run leaner. This makes sense with methanol as the effective octane would be basically race gas--I believe it would be around 110 with the methanol and 91--in either case, definitely in race gas territory. The rule of thumb is also that you can/should run motors leaner with methanol but even 12.5:1 makes me really nervous--not to mention the 20 degrees of timing up top on a stock compression motor. If I had a low comp, I would feel much more comfortable--then again, I don't know these motors as well as many of you do.
A note on the boost, we made 620/680 with 18.5psi peak. This is where I really wish I had the graphs to show you guys--I might try and run back to the dyno and get them. In comparison, the 581/640 pull only made 16.5psi of peak boost and in many parts of the graph (4500rpm and down), it made MORE power and MORE torque than my 620/680 pull, with 1-2psi less boost. So I'm thinking adding timing and/or leaning it out made the motor more efficient--after all, boost is a measure of restriction--it just seems much happier with the 4 degrees (as opposed to 0) down low. The top end of the pulls were similar though with 20 degrees and a leaner AFR, it was much smoother. Or perhaps the cams are strange and require that sort of timing (though the VCT is locked out)--I am not very good with cam profiles so if the ones up top look strange to any of you, please chime in with any info.
So my questions are:
Does 581/640 seem right for a 326 + 2.3L whipple + methanol, 12.5 AFR, 16.5psi, and 20 degrees timing up top?
It seems the car would make even more power, just comparing graphs yesterday, it seemed it would have hit well over 600hp and almost 700 tq if we just threw more timing at it. All pulls were clean, no detonation that we could hear (though we can't be sure because the iron block from Brenspeed does away with the knock sensors).
Second, how much timing are you guys / would you guys run with a set up like mine? I have looked at some other tunes for Whipples/KB blowers and some run as high as 28 degrees up top--that is just plain scary to me, as my understanding was these 3v motors don't need that kind of timing to make power.
At the end of the day, I'm not looking to put down record-breaking numbers. I realize the 2.3L whipple is the WRONG unit to make huge power but looking at all the signs, it seems low.
Is running 4, maybe even 6-8 degrees of timing in the 2000-4000 RPM range a big no-no? Is 12.5 AFR too lean? I know some guys run their race cars with methanol injection as lean as 14:1 with boost but mine is just a street car--I'd like it to last forever.
All input and opinions welcome! At this point, I am almost ready to throw in the towel. If anyone here knows anybody with real experience with a set up like mine, I'd love to pick their brains a little. My other alternative is to ditch the methanol altogether--but I don't think it could really be hurting anything.
One more sidenote, has anyone seen the stock 3v coil packs go bad a lot? The wiggly dyno charts made me think they were going out. Pull after pull, it got worse and worse. I hate to just throw parts at it when it won't fix an issue. This was before leaning out to 12.5 and adding timing--which made really clean straight pulls, as I said before. So that makes me think it's NOT the coil packs. I put brand new plugs in it yesterday too before the dyno. If anyone thinks going to an MSD coil pack would help, I'd highly consider it but at this point, I don't think the problem is in the hardware.
Lastly, I am running a stock Whipple intercooler, heat exchanger, and pump--my IATs are right around 118-120 degrees--which seems fine to me. This should be a post-methanol intake charge as my IAT sensor is in one of the intake manifold runners.
Thanks in advance!
Code:
Brenspeed B326 Block 9.8:1 Compression
2.3L Whipple /w 10-rib kit, puts down 16-18psi...this is where it gets funky (more on this later) -- Whipple blower has 10-rib kit but everything else is as it comes from Whipple (Whipple Elbow, Whipple Intake/Filter)
Stock Throttle Body
Snow Performance 50/50 Methanol Injection, using since 675ml jet, spray starts at 1psi, max set to 18psi.
Anderson Ford F-53 Cams ([URL="http://i650.photobucket.com/albums/uu223/letsdoubleupthedorito/photo_zps0e68b142.jpg"]Click for Specs[/URL])
Anderson Ford Valvesprings ([URL="http://i650.photobucket.com/albums/uu223/letsdoubleupthedorito/DSC_7413_zps1a315fd7.jpg"]Click for Specs[/URL])
Stock Heads
BBR VCT Lockouts
Stock 5-Speed with McLeod RXT and Aluminum Flywheel
DSS Driveshaft
3.55 Gears, factory LSD
Factory Exhaust Manifolds
O/R H pipe w/ Corsa Straight-Through Mufflers
80lbs FRPP Injectors
Fore Fuel Rails
Fore Fuel Hat, Dual 450lph pumps (return style)
Fore FPR
Fore FC3 Fuel Pump Controller (2nd pump on hobbs switch)
Brisk Silver Racing Sparkplugs
Kenne Bell Boost a Spark
Thanks in advance!
