Shifter assembly front mount insert
rob inforzato
Downingtown, pa
I managed to bugger up the metal bushing insert for the front shifter mount while installing a Hurst shifter (the Hurst shifter reuses some of the factory bushings) on my 2008 Bullitt. The insert is still usable, but I'd like replace it to remove the chances of any issues down the road. I've searched the web but the part doesn't seem too be available separate from the whole assembly. Any suggestions are appreciated.
is your question on where to find the buggered part?
rob inforzato
Downingtown, pa
Yes, sorry if I wasn't clear, I'd like to replace the buggered metal bushing insert with a non-buggered one, or something else that will work. It seems kind of lame that Hurst makes you reuse some of the factory bushings.
JC SSP
FL
Have you tried contacting Hurst directly?
