So sick of waiting.
alexthejew
Jewish and lovin it.
so i got sick of waiting for new rims to fit my car. new rims can always be fitted for a car. i took out my rear perches because the eiback setup was too high in the rear. result:
ok, so maybe the fenders need to be pulled. im planning to pull the front today too and im thinking about buying spacers to fit my gt500 brakes. i have bullit replica rims 18x9 in the front. they dont fit the brakes. according to MY measurements a 45 mm spacer should do the trick. i just want to make sure that my brakes will fit. has anyone done this before? all help would be great.
thanks
alexis
Kaldar142
Silver Spring, MD
wait... a 45mm spacer? are you on crack? lol
that is HELL on your hub bearings man, youll replace them every 1000 miles... not to mention the car will handle like crap and look dumb
alexthejew
woa man. dont hate. the fenders would obviously get pulled to fit appropriately.
DRock
That aint fender pulling that is widebody at that point
alexthejew
eibach pro streets...
... the stock spring doesnt have a perch. the perches on the eibachs are just so you can adjust it. vdubbers have done it for generations.
tached_out
Bigger the better
I wouldnt "pull" your fenders your going to more then likely do more damage then what is good or potentially make the rear end look like crap.
I would just be patient and get some new wheels and not try to reinvent the wheel. If pulling your fenders was a good Idea then I think every drag racer with this car would of done it by now
Kaldar142
Silver Spring, MD
Im not hating, i'm looking out for your WALLET and SAFETY
do NOT run a 45mm spacer, i ran a 25mm spacer on previous cars and had to replace the hub bearings often, not to mention the car tramlined like no other
Vapour Trails
The Renaissance Man
Winnipeg, MB, Canada
Dude, that's hella tyte. Don't worry those hat8ers that aren't mad ballerz don't understand that those fenders will be like the matin' call to bitches
alexthejew
thats not exactly how i would have worded it, but pretty much.
don_w
Dyno Numbers - Who Cares?
San Diego, CA
The good news is, with 45mm spacers you will be able to clean the inside sidewall of the tire without even bending over. :omfg:
