Tron
GT500 dual fuel pumps : $250 FIRM shipped. The pumps have about 15,000 miles on them. the setup will come with 2 FPDM's, a stock one and the kit one. The power wire was cut due to the car being in a collision, this makes it a perfect candidate for the numerous power wire upgrades available in the aftermarket. The female fuel level connector that comes with kit is not included as i was in a time crunch while pulling the setup out and forgot to remove it. you can either hardwire it together or you can purchase the connector here : http://www.mouser.com/ProductDetail...54200207/?qs=sGAEpiMZZMuSK2mCDyT9cuUG59A6S/n9
The lines do have some abrasions on them from the original install as well as when i removed them. They are cosmetic and will not harm the performance in anyway. You will most likely add some of your own when you install the pumps as they are a tight fit. You will also need to purchase a sealing O-ring. the locking ring and the cover will be included.
TiAL Q BOV: $100 OBO shipped. The BOV has the unpainted spring in it (-10psi spring pressure). The BOV does have some scratches and 2 scrapes on it which are pictured. It comes with the mounting clamp and the banjo barb fitting. One of the cap rentention bolts is in pretty tight(pictured next to scratch). I was attempting to remove it but without it mounted to something and with just an allen key i was scared i would do more harm than good. it was the only bolt i couldnt remove with an allen key so just a heads up there.
Drake Bumpsteer Kit $40 OBO shipped. The rod ends are still very tight but you can see in the pictures where the inserts are chipping away. i was running them quite awhile in this state before i noticed and they were still very tight with no play. i was going to try and contact drake to get them fixed but i have run out of time to do so. A DIY'er with some CNC or Lathe skills could maybe use them and get a good setup for cheap.
All items can be picked up in Ft. Bragg, NC for an even better price. PM me with any questions.
