Speedbleeders for GT500 Brembos?
ArizonaGT
Road Course Member
Phoenix, AZ
Hi guys:
Does anyone know the part number for the Earl's or Russel speedbleeders that fit the Brembo calipers?
If possible, link to product on Summit or other website? :)
Thanks!
ArizonaGT
Road Course Member
Phoenix, AZ
Yep, you can use the same part number on all four corners. They do make life pretty easy!
Ok, cool. Already using that same type on my GT calipers, didn't know they were the same.
Thanks for confirming, my GT500 BBK should show up sometime in the next week or so :D
Mustang30212
Columbus, Ga.
When bleeding these brakes....do you start with the top one or the bottom one first?
RH
Miracle
"Shall not be infringed"
Clarksville, TN
RH
Start with the bleeder that is farthest from the brake line, which would be the one on the OUTBOARD side of the caliper. They are both on the top, one inboard, and one outboard.
What I did when I installed my Brembos, was to REMOVE the bleeder on the outside, have my friend LIGHTLY, SLOWLY press the brake, until fluid came to the opening, and reinstalled the bleeder, and did the same for the inboard one.
Then bled the brakes using a vacuum pump and repeated the process for the inboard side.
