raidernixon
- Joined
- Feb 9, 2015
- Posts
- 2
- Reaction score
- 0
Hi all,
I searched the forum and didn't find anything that seemed to be the same issue. Apologies if this already has a topic.
I've got a 2011 GT with the manual transmission. 98,000 miles to date. Bone stock with exception of Roush axle back exhaust.
Battery replaced in July 2014.
A/C Compressor (failed clutch) was replaced in August 2014.
I am looking for a little bit of diagnostics help to determine what might be going on. About 4-6 weeks ago, the car started experiencing inconsistent periods of RPM surging (maybe once a week), with more common and persistent occurrences (multiple times daily) of what seems to be rough idling (beyond that of the typical coyote idle stutter) and minor RPM surging. No engine codes to date.
I have been keeping the car in engineering mode to monitor the RPM surging.
450-1300 RPM is the surge range for the less common occurrence. Each time this has happened has been after a cold start and driving for about 1-2 miles and coming to a stop. There is a noticeable popping sound from the exhaust during the episode.
500-950 RPM is the surge range for the daily occurrence and happens anytime between cold start up, warm start up and idling situations in traffic. You can feel a slight shutter in the car whenever it is going on.
RPM is steady outside of the idle range.
So far, I have pulled out the original spark plugs. They appear to be OK but I am going change them out since they are old and may still be a factor.
I am going to take a look at the mass airflow sensor tonight to see if it might be dirty. Otherwise, I am not really sure what else to check for.
Does anyone have any ideas or suggestions of what else I should check out while I am under the hood and what might be causing the surging?
Thanks in advance for any help.
