stock crank limits ?
retfr8flyr
The Old One
Providence Forge, VA
Jeremy of S&H Performance. As long as you keep the RPM's down, under 6500, the stock crank would be good for 700hp at least. The cast crank doesn't have the balance weights to handle high RPM's, other than that it's a very strong crank.
Earl
irishpwr46
Official Site Vandal
NYC
if youre going throught the trouble of replacing rods and pistons, why not save a little longer for a better crank?
19COBRA93
Ford Racing
Clinton, Ut
Don't hear about cranks breaking very often. I would think between 600-700rwh would be a reasonable limit.
ncpower08
Angier NC
^^ what he said^^. Eagle has a kit with a crank rods and pistons. I would go that route. It is the most bang for you buck.
anyone know what a stock crank will hold with forged rods and pistons f/i with conservative tuning ?
I've built two motors that way. Never had a problem. When I built the first one the internet max was 450rwhp. Now it appears to be 700. The fact is nobody has broken one. And contrary to what you may hear it has counterweights, just not the two center ones. The rotating assembly balances just fine without mallory metal.
How high have you pushed an Eagle kit? People have reported runout problems with the Eagle cast crank. What was your experience?
702GT
S197 Fanatic
Las Vegas
Not to step on his toes, but...
Eagle uses Arias pistons I believe. I don't know a soul running Eagle internals, or none that admit to ever having used them. That speaks worlds for itself. I trust my stock internals more than anything stamped Eagle.
ncpower08^^ what he said^^. Eagle has a kit with a crank rods and pistons. I would go that route. It is the most bang for you buck.
I had a conversation with a Rep from Eagle at the last SEMA here in Las Vegas. He tried to tell me that because Manley doesn't mass produce its internals like Eagle does, that Manley internals have a greater chance for flaws in the quality of their product. Where Eagle mass produces their internals, using only the highest quality russian/chinese metals.
No bullshit, that statement came straight from the horses mouth.
Chinese steel bolted to the sides of my heads to route exhaust and give me excellent exhaust note and torque? Sure. And when I burn holes in them I'll chuck them on the scrap pile and buy another cheap set 'cuz it only takes me 1-2 hours for a header swap.
Chinese steel/aluminum pumping in my motor at 7,000rpm? Are you for fucking real? Eagle is not THAT great of a "bang" for the buck over Manley. Unless you like the kind of "bang" that you're going to want to put to your head when you wish you hadn't been a cheap fuck and skimped on the shit that holds your motor together.
:wtf1:
Eaglestroker may have somethings to say about your comments /\
weather man
Persistance Is A Bitch
MN
Don't Sugar Coat it Man!!
Not to step on his toes but.....:flamethr:
:roflmao:
sportinawoody
Piedmont area , N.C.
Iwas just going to do Manley rods and pistons were up in th air. I'm not planning on going no higher than 15-17 lbs so 600ish is where I want to be. And I already shift it @ 6000 so I'm not spinning it up past 6400 at the most just to prolong my engine. If it were a race car id go all out but it's a cruising toy that sees the track twice a year. I'm already making 480 on 10 lbs with 15 degrees but i need a little more to be happy.
I've been running my stock crank to 650rwhp and 7k rpms for awhile now no issues.\
Stock crank, manley h beams and diamond 2618 pistons.
Im going to be pushing it to 750rwhp soon. I may go with an ati superdampener before though.
Mustang30212
Columbus, Ga.
Just pick up an 03-04 Cobra forged crank along with an 8 bolt flywheel. Cheap insurance.
Then again...700rwhp with a stock crank is probably more than most of us will ever see/use.
RH
Dillon Dollar
oklahoma
I'm in the same boat as Jeremy and you op car made 630 rwhp with Mahley rods and pistons on my stock crank new blower will be here next week so I'm going for more powa.... I was skeptical about going above 650 but since several people say 700 is doable i may try it... I do have a cobra crank ready for install at a later date as well and I shift at 6800 rpm
GB10
8s coming soon?
Burleson, TX
This has been the case with 2 of 3 Eagle cranks I have installed in a 4.6. One checked out fine, but 2 others had runout issues which required extra machine work to fix.
Basic answer
An inspection performed on a reciprocating engine crankshaft to determine the straightness of a shaft.
This may be a newb question but what is runout
Deviation from center during rotation. Say you put a piece of round stock in two v blocks and rotate it with a dial indicator measuring the differences. The differences would be runout.
