Strang shock/strut settings 2013 cj springs
Devcon 7
Wichita
Just curious what you guys put your shocks and struts at? Putting on some right now and didnt know where to start at. 3V stick car with a pd blower weighs 3550
wbt
Full soft on front and 5 clicks from full soft on the rear.
cm581978
NJ
Why are some making the settings stiffer in the rear and vice versa.
808muscle
Maui
Thanks guys, now have ds rubbing...ugggh
If mine are set soft at all it will rub my DS too. Mine are set to 8 almost full tight front and back . That's what works best on my setup, no rubbing, and cuts great lights.
2011/5.0
Iowa
I run mine at 2 front and 4 or 5 rear depending on track prep. Your 60 ft will tell you if your rear are too stiff, it will vary a bit due to slight spin you may not notice. Just start at 4 rear and go up till its too much for your prep and tires
