Department Of Boost
Alpha Geek
- Joined
- May 26, 2010
- Posts
- 8,809
- Reaction score
- 28
Replied in the quote.
a supercharger, especially a PD style is super easy to install, no big piping to route around the engine, just bolt it ontop, extend any wiring you need, and run coolant lines which are a lot more reasonable than 3" pipe
Some kits yes, some no.I thought all PD blowers require some machining of the timing cover?
Yes.I will say the centris are a pain in the ass to pipe around;
and Bruce is also right in saying there's a point of too much power for the street - it doesn't seem to be all that high.
Livernois just posted this yesterday. I don't know if this is what you're looking for but it's an intercooled Magnuson TVS 2300 kit for $5k. Install & tune is offered for another $500. No cutting or modifying of the timing cover needed.
Link to kit:
http://www.livernoismotorsports.com/product/LPP499103
Kit + installation & tune:
http://www.livernoismotorsports.com/product/LPP0104914
I've always been a HP junkie. I raced Superbike for many years (200rwhp/365lb). My idea of "reasonable" is rather skewed. But after maturing a bit I agree with Bruce. I've had lots of time in 450-1000hp street S197's. And I think 550-575rwhp is the happy spot. It's plenty damn fast. You actually have to drive the car. It's also the point right before things start getting really expensive and the "Street Car That Is Fun To Drive All The Time"/ "Race Car" line. There is a certain point where it's not worth the time, aggravation, money, etc.
Yep!
I can't imagine what your car is like to drive in city traffic with the high stall.
When I had the 2.3 Whipple on a 4.6 making 599 it required a whole lot of focus when leaving a stop light. Any amount of throttle that would close the bypass valve would put 16psi from the twin screw into the motor instantly. Even at low rpms it triggered a whole lot of torque to the wheels which created unintentional wheelspin. Not a good thing for normal, in town driving when leaving a stoplight.
It was more focus (driving, as you call it) than I wanted to put into a trip to the store or work.
My current motor with a M122 and 7psi making almost the same power was far easier to drive in traffic because it wasn't slamming 16psi into the motor at low rpms.
IMO a centri is the easiest to drive like a normal car (just drive, not have to focus as much) because the boost is rpm dependent so there just aren't as many surprises.
That's weird to me. I've never had an issue with that on any PD setup from 450-1000hp. I think they all drive like regular cars until you jump in them. Just yesterday I was driving a PD Coyote car with short gearing........with icy rain on the road. It was no big deal at all.
At 13psi it wasn't a big deal at all. When I went to 16/17psi and a larger tb it was important to pay attention when leaving a stop. It crossed some sort of line for my setup and that line required a whole lot more attention to driving.
As you know the Whipple twin screw delivers all the boost as soon as the bypass closes because a twin screw is always compressing. The bypass closes as soon as vacuum drops which happens when enough air enters the motor. The larger tb allows more air to enter with less blade angle, reducing vacuum quicker than with a stock tb.
Take off from the stop with just a little too much throttle and it was instant wheel spin. I'm not saying I had to take off at idle, I'm saying that it wasn't like driving my pickup, etc. If for some reason I stabbed the throttle just a little too far it crossed the line and really looked like an asshole having a midlife crisis instead of someone driving home from work.
A centri with more power is much more traffic friendly because max boost isn't happening unless the rpms are higher. It's also not as fun on the street for the same reason.
Remember that I lived with the setup. It was driven to work on a daily basis in all weather. The commute is 15 miles one way of mostly urban driving with lots of stop and go. Lots of chances to accidentally stab the throttle.
The few times it happened were enough for me to realize that setup was more than I wanted. It's also where my own personal "fun car" line at 525-550rhwp for this car comes from, my own experiences with the car as a daily driver.
With all of that said the car is now a garage queen except for weekends. It may well be wearing a DOB setup in the next few months. I'm thinking that my current motor should handle 750 or so fairly easy and it shouldn't be that hard to get there with 12:1 compression. More to come on that.
I wonder how much that has to do with the bypass valve. The Whipple stuff is usually their "race" bypass, so they hit harder. They do have more sedate options.
It may be a combination of things too. Like gearing. I tend to gear my stuff pretty high. I'm speculating that they aren't going to hit as hard as something geared "short". You're geared pretty short aren't you?
Were you using a single blade TB? I know the one time I used a single blade I found it really snatchy.
IIRC I had 3.55 gears at the time with the TR-6060 transmission. I've had 3.55, 4.10, back to 3.55, back to 4.10, 4.56, and back to 4.10 over the 8 years I've owned the car so sometimes it's hard to remember.
I do know that the current 322 inch motor with 12:1, FRPP heads, etc. didn't have the issue with your DOB kit and a M122 making 7-8psi and just a little less power.
The TB was a FRPP 62mm. The tune had the stock commanded torque table, it was before I had calibrator status (calibrator status is needed to have access to the drive by wire parameters) and had just started learning about engine management. So I know I wasn't doing something stupid like commanding a bunch of torque at a low pedal position.
Anyway all I was doing was offering a perspective for the op that is based on my experiences. He has a lot of choices. In a way it's like sex, it's all good but some are better suited for his personal preference and driving style than others.
Received a quote from JPC for 11k, which includes a 2.9 whipple tuner kit, ID1000, fuel pump booster, iridium plugs, install and tune. The install and tune alone is $2800.
Other option I'm considering is the VMP stage 3. I can order for $7500 and have a shop around here do the install. I'd estimate the install price around 1k. And Justins kit comes with a tune already. So 11k vs $8500.
Is the JPC package worth the extra $2500?
Damn that's a steal!
Yeah the kit is very nicely priced. And with how much a tune would be the tune+install for 500 is sweet, not having to wrestle it and cuss for a day or two because you lost a bolt or anything
