Supercharger oil
gary2014
Fredericksburg, VA
I have a 2014 5.0 with a Roush R2300 625 stage 2 HP Supercharger Kit that's bin on the car for 3 years now. When dose the supercharger oil have to be changed and how...
Thanks
JJ427R
Did not know you had to change it and have never heard that. I've got a 2010 with the M90 and have never done anything to it in 50,000 miles and 25 track days... How would you even change it, pull the unit apart????
drive_55_not
The Eaton SC oil is fairly robust and is rated for 100,000 miles, I've put 80,000 miles on my TVS changed it a couple times ...
You'll need 8oz as roughly 6oz of oil should come out and go back in.
The easiest way to change it is to pull the blower , Remove the allen drain plug in the front cover, Drain the oil into a cup, and pour that amount back into the gear case,
Make sure the hole is clean before you refill , Use a drop of blue loctite, clean and reinstall the plug ...
If you don't wanna pull the blower, get an oil change kit with a syringe and use it to suck the oil out, and refill.
https://www.ebay.com/itm/Two-GM-Sup...9:g:1hUAAOSwSMZbcfti:rk:1:pf:1&frcectupt=true
