Supercharger reservoir tank & pump with radiator tank. It is a GT500 pump from Bosch. The pump is connected to the bottom of the tank. Next to it is a tank for the radiator. These fit where the stock battery goes. You have to move the battery to the trunk if you haven't already. It uses the stock radiator cap so mine isn't included as I am using it. The fittings on the pump are 3/4" hose off the pump and -12 return line. There is a -12 fitting on the bottom of the radiator tank that goes to the hose which feeds the system and the over flow connects at the topside of the tank. No additional hoses or fittings are supplied what you see is all you get. I want $250 includes shipping in the 48 states and I'll only sell to ship in the 48 states. I live in Michigan.
