I have a 2010 mustang gt (automatic with shift kit and ratchet shifter) with a edelbrock supercharger about to be on 9lb pulley and thought my car had a 3.73 but did the tire/drive shaft rotation and came up with 3.31 so question is...what gear size do yall recommend? Iv done reserch seen lots if different answers but wanted to hear ya'lls opinions! Personally I'm thinking 3.73s, thanks for responding and any advice you guys!
I have a 2010 automatic with a small M90 blower. (390 rwhp, 460rwtq).
With the oem 3.31 rear gear and 5r55s auto tranny, + 26.97" tall tires, ( 285-40-18) for DD use, you will burn the rears off in 1st gear. And traction in 2nd, ( after an eaton tru trac /watts link, BMR lca's and lca re-locate brackets installed, along with BMR uca, etc, etc. )
Final gear ratio is just the rear end gear... multiplied by whatever gear you are in....in the auto tranny. ( then factor in rear tire height).
Turns out that 2nd gear on the 5r55S auto tranny is 14% lower than 2nd gear on the TR3060 manual. 3rd gear on the 5R55S is 16.5% lower than 3rd gear on the TR3060 manual !
IOW, you would require a 3.73 rear gear on a TR3060 in 2nd gear to equal the 5R55S 2nd gear + 3.31 rear gear.
You would require a 3.90 rear gear on a TR3060 in 3rd gear to equal the 5R55S 3rd gear + 3.31 rear gear.
Unless you are a hardcore weekend drag strip racer, I would leave the rear 3.31 gear alone.
Folks with a TR3060 + 4.10 rear gear + 29" tall tires is a different story. The 29" tall tire will effectively render the 4.10 rear gear into a 3.813 rear gear. (26.97 /29.00 ) x 4.10 = 3.813
IMO, if you have a 2010 auto..+ blower + 27-27.3" tall tires, leave the oem 3.31 rear gear intact...esp for DD /street / hwy use. You are already geared low enough in 2nd + 3rd gear. Put a 3.73 rear in there, and you will just burn the rear tires off in 1-2-3.....for dd /street use.
