danzcool
- Joined
- Feb 5, 2011
- Posts
- 46
- Reaction score
- 0
Ok, hopefully this is considered tekkkkk.
My right tailight & flasher is not working and I'm not sure where to check from here.
background:
I've replaced the bulbs asa first step, no change.
I have the webelectric sequentials (which clip the 'crossover' tail-light wire) and was getting nothing, but the backup lamp does work.
I swapped the original harness back, and verified the 'crossover' light does work (dark-blue/yellow), but that the right side tan/red wires do not work.
Right front flasher and running lamp do work.
I have not yet tested if the left side 'crossover' from right works (tan/red).
It 'feels' like there is a fuse or module that that needs replacing, but I can't find any information that shows the circuit in it's completeness, just abstract portions.
Any suggestions on what to check next before I start cutting into the wire harness to check where the issue is?
Thanks.
background:
Thanks.
