SoundGuyDave
This Space For Rent
- Joined
- Apr 9, 2007
- Posts
- 1,978
- Reaction score
- 28
So, I had a wee bit of an off-track excursion in April in my Time Trial Mustang, finding some double-high Armco at around 70mph... The car is DONE as a "street" car, but has a bright future as a race car! I've been turning wrenches on it as time permitted since the incident, and I'm close to getting it back on track (no cage yet, so still TT), but there are a few niggling little issues that I still have to resolve. If anybody can offer any tech help, I would certainly appreciate it!
1) Evap tray: The rear sensor (actuator?) in the pan seems to use a different connector between 2006 (chassis) and 2008 (body harness). Is there a functional difference, or is it just a revised connector? Easy enough to swap pigtails around, but if I need to change out the sensor itself, I would rather know now, than the day before the next event.
2) Does anybody have a schematic for the ignition switch with the color codes? I'm pulling the key out, and setting up a toggle-switch bank.
3) Heater core delete: How have you guys handled the plumbing when deleting the heater box? The lines are two different sizes... Also, it's a 2006 engine and cooling system layout, if that makes any difference.
4) Package tray: Is this a structural piece? I'm going to cage the car over the winter, but if I can pull it now with no ill effects, that would be a plus.
Oh, if anybody needs any interior bits, let me know!
Thanks in advance!
Thanks in advance!
