Finally got a package together for the TVS guys. It's a pretty complete package that should work for a lot of the guys, but should be a decent savings for you at $6999 before adding / deleting options. We still have great deals on all the Phase 1 to Phase 3 calibrated kits as well!
The Beefcake Special - "ROUSH"
Our Custom Roush kit includes the following!
Lund Remote Custom Tune
ID 1000 or 725 CC Injectors (your choice).
85mm or 80mm Supercharger Pulley (your choice).
2085mm Supercharger Belt.
Roush R2300 2011-2014 featuring new TVS Technology. The new Twin Vortices Series features new four-lobe rotors and high-flow inlet and outlet ports that greatly enhance thermal efficiency, enabling greater volumetric capacity at higher revolutions per minute (RPM) Capable of producing over 850 horsepower.
High flow fuel rail.
ROUSH Fuel Pump Voltage Regulator to moderate fuel flow and ensure a proper fuel-to-air charge ratio with Plug-n-Play wiring harness where no modifications are needed to the vehicles fuel pump wiring system.
Fuel charging assembly with ROUSH designed upper and lower aluminum intake manifolds
High efficiency intercooler system featuring a large full face low temperature radiator, over size coolant degas bottle, high capacity air-to-water intercooler and formed hoses with abrasion-resistant sleeves
Twin 60mm throttle body spacer
ROUSH cold air induction system with 110mm MAF tube, washable/re-usable open element air filter and air dam.
