The what does it mean thread..
Mickey
Detroit
Need diffenations! What is a SB vs a LB? Where does a small block stop and a big block begin? etc.
Mickey
Detroit
PVC skin material of componennts mostly I/P's (instrument panels and doors)
PPO retainer and skin material for interior components
TPO internal components and front and rear fasica's
PC/ABS internal components material(rigid/brittle)
SRS supplemental restraint system (air bag door)
SIR supplemental individual restraint
HVAC Heat Vent and Air Conditioning system
HUD Heads up display
TUP Test until pass
TTF Test to failure
ZmanM3
The Evil One
Jackson, NJ
Its already in here but:
SB = short block (no heads)
LB = long block (everything except the front dress and transmission)
let's keep this a tech topic thread please.
klaw
Calgary, Alberta
AA / AB heads - The 'AA' 3V heads (approx pre-'08) use the notorious barrel-style sparkplugs. The 'AB' heads are the new style all-thread design.
MikeVistaBlue06
Inventor: Asshole Points
Richardson TX
How to tell what a resistor is
A resistor usually has 4 colored stripes on them. The first 3 tell you the value of the resistor and the last one tells you the tolerance.
There is an old mneomic we used to remember the colors. Sorry ladies, but this is how I learned it:
Bad boys rape our young girls, but Violet gives willingly!
Bad---------Black-------0
Boys--------Brown------1
Rape--------Red--------2
Our---------Orange-----3
Young------Yellow------4
Girls--------Green-------5
But---------Blue--------6
Violet-------Violet------7
Gives-------Gray--------8
Willingly-----White------9
The first two stripes tell you the first part of the value.
The 3rd stripe is the power of 10 multiplier.
For example 1000 ohms is 10 x 10³ = Brown Black Red
220K ohms would be 22 x 10^4 = Red Red Yellow
1M ohm = 10 x 10^5 = Brown Black Green
47K ohms = 47 x 10³ = Yellow Violet Orange
The last band is the ±% tolerance of the resistor:
Gold = 5%
Silver = 10%
No band--who knows!
HTH
Mike
