Does anyone use one? I took a couple measurements over the weekend at VIR full course. Any thoughts on what the tires are trying to tell me?
Session 1:
Set pressure to 39psi all around before a 30 min session
Drivers front:
Outside 50C Middle 53C Inside 55C
Drivers rear:
Outside 55C Middle 57C Inside 56C
Passenger front:
Inside 55C. Middle 54C. Outside 53C
Passenger rear:
Inside 55C. Middle 56C. Outside 55C
Session 2:
(Checked tire pressures after the session this time)
DF
Out 52C Mid 56C In 56C 46.4psi
DR
Out 57C Mid 60C In 58C 47.2psi
PF
In 57C Mid 56 Out 55C 45.4psi
PR
In 56C Mid 60C Out 58C 46.0 psi
Tires are 295/35R18 BFG G Force Rivals,
Konis set to 3/4 firm in front, 1/2 firm in rear, camber set at -1.5 degrees.
Thanks for any guidance
Session 1:
Drivers front:
Drivers rear:
Passenger front:
Passenger rear:
Session 2:
DF
DR
PF
PR
