tr-6060 TOB mcleod install question?
Androdz
Banned
If ur a tool you deserve fire!
I have some doubts about the TOB. It looks like I gotta grind where the stock one sits so the Mcleod unit will sit perfectly and wont have the inner part portruding out(where you slide the TOB in). Tried calling but it seemed I kept getting x-fer to sales...
andrew
oh I'm sure you'll get some really good responses now!!
:popcorneat:
94tbird
4R70W FTMFW
NY/NJ
mcleod TOB = pure shit same as the ram. way too many failures. in fact i think more of these aftermarket TOBs have failed than have actually worked
chad05gt
Lake Charles, La
OEM tob and zero problems :)
Im using RAM Powergrip HD with RAM flywheel with OEM tob , yes the green one, and zero problems:thumb:
Androdz
Banned
Ok I found out what the problem was. I had to mill down the bronze piece to make it fit perfectly on both ends and I replaced the screws with some better ones that dont protrude out of the TOB. I am almost sure this will work. Now I am having problems with the kr-shifter I bought I will have to cut it to make it fit...
