TorchRedV6
this has happened a couple of times and it happened again tonight. im driving along and when i go to gas it (not floored just normal acc.) the traction control light is illuminated and there is no acceleration at all. each time this has happened it goes on and off and will be fine and in power for a few seconds and then the TC will light up and stop me from accelerating. each time i have just put the car in neutral and turned it off and then started the car again. that clears the issue up fine. it has happened 3 times now and its been about a month in between each occurrence. any idea as to what is going on? is there some sensor that might be bad? no noise is made when this occurs if that helps.
thank you in advance for any help
