Up for sale is a Tekonsha 9030 Voyager Electronic Brake Control wired with a connector for select Ford F-150, Lightning, Harley Davidson, and F-250 series pickups with the factory 7 pin wiring for trailers with electric brakes.
I had this in a 2004 Ford F-150 Lighting, but sold the truck and don't need it anymore. Works great. Comes with instructions, DVD, mounting screws, bracket, factory box, and a Ford pig tail connector already wired up to it.
Pig tail is the Ford part number F85B 14A348 P260Y. Check with your dealer to make sure this part number will fit your factory Ford wiring connection under your dash for factory installed trailer brake harness. There are also two fuses that will need to be installed in the fuse box to get this to work with select Ford vehicles.
If you change out the pigtail, you can use this brake controller with hundreds of other vehicles. Check with your dealer to make sure it will work.
I paid close to $100 for it, sale for $40 shipped in the conti US.
