transmission question
SC boss
watch this!
Desloge Missouri
I have the PA deep pan with PI multidisk converter and my question for all of you is......
How many quarts of fluid should this hold? Yes it has the dip stick but I cant get a good read off of it. I put 11 quarts in it and it wouldnt shift properly so I called Tony and he said that It should have around 15 in it so thats what I put in it now and the dipstick reads WAY off the chart. And driveing it I notice a little transmission noise (may just be something rubbing) and it also made a little squeak when shifting into third gear two different times. Any suggestions?
I dont know whats recomended but my aeroforce showed the highest trans temp at 173 degrees
Thanks,
Shawn
psfracer
billy badass
Valencia, CA
I put 13 quarts in mine when I installed the trans last year.
The "squeak" you hear when it shifts into 3rd/4th---could be the belt on the s/c? Also, with the PI multi disc converter, when you go into o/d it will grab and the car may lurch forward a bit.
Hawgman
THE fucking bad guy
Texas
Mine "lurches" hard enough that it actually causes belt squeal. And that is with an 8 rib kit and a gripper pulley on the blower!
A John In NJ
Rice Cooker
NJ
I get that too!!! I changed the belt and it still does that... the lurch thing... but mine is from 2-3 and 3-4 gear... Im really thinking about getting rid of this auto and going to the manual.... so many problems with this trans or is it just me?
