Bullitt6301
- Joined
- Apr 19, 2013
- Posts
- 164
- Reaction score
- 0
So I have been tuning my turbo 3v with a ba5000 maf and 47lb injectors and everything is pretty well tuned below 3000 rpms. The issue I am running into is I have it in forced open loop and I am trying for a WOT run and it will do what I am commanding until the full 9 psi is built but at what seems the same rpm/load the engine will lean out and really lose power. I back out of it as soon as it gets to 12 but it is sudden. I have riched the maf a lot but it still is not responding. I am logging good frp, volts, ect, fpdc. I noticed that in the log that it will build timing as the load increases but as soon as it hits 1.10 or so it pulls timing to 8* and that it about the same time the car leans out and falls on it face. I went back and checked the spark tables and everything is good. I was looking through my tune and I was looking at the vct tables and it was all zeroed out because I forgot that the original tune I was going to run locked timing gears but instead I am running stock vct gears now. I set the table to stock but haven't had a chance to try and see if that would make a difference. Would this be more problem?
