turbo install
joeycol5
So I just purchased a turbo kit for my 06 gt.. it's a modified on3 kit with a precision 70/68. Have a few questions before getting started such as what type of fuel pump and injectors I should use. And what i should do to the motor it self to hold up to the boost... I'm aiming for 550-600 hp. Thanks in advance for any non trolling help lol
joeycol5
What rods and pistons are recommended I wanna do it right. And anything else besides that?
psfracer
billy badass
Valencia, CA
There are a lot of threads about this. You can search the multitude of engine builds on here.
I would definitely build the bottom end. Kellogg crank, Manley H beam connecting rods, some Diamond or Manley pistons, etc. Research the engine build threads on here.
Ingwe
Sun, Sea, Sand and Camels
Dubai
Good choice. Loads of few awesome turbo builds on here, some still in progress. Run a search and you'll find everything you need.
roberts
Bonne Terre, Missouri
I got .20 over cp pistons and cp rods with all arp hardware. stock cranks 700rwhp is what the crank has been holding.also are u wanting to do 93oct, e85, or 110octance?
johnnyv8
South Jersey
Your also going need a better trans (TR-6060 for a stick). I'm not sure what is done to your car, but if you drag race. Start saving for even more stuff, such as diff, control arms, etc.
jodadejss06gt
TEAM DELETE SHIT
Severn MD
Go on Modmax.com and browse the inventory there. Forged H-beams for reliability, any of the forged pistons should be good as well. They even have some short blocks you could buy. I have twin gt500 pumps/hat you could buy if you need more fuel or you could probably do an upgraded single pump if only going 550. You'll most likely need 60lb injectors.
joeycol5
Car will be drove often mostly just on just on the street so 93 octane would be what I'll be using. Car is completely stock btw. So iv been 60# injectors by some and 80# by a few others.
TexasBlownV8
Formerly TexasBlownV6
Central Texas
Without a built motor, you won't be needing anything above 60's.
Until you build the motor, just keep the boost low (6 psi or so), so as to not put out too much power and break a rod or piston.
joeycol5
Look I'm new to the forum looked around didn't find all the answers I was looking for if you don't wanna help that's fine keep scrolling on the other hand thanks to everyone who has helped and doing what these forums are for...
BEAST
CHEROKEE NOOB HUNTER
Houston, Deportation Central, Texas
Reading comprehension? Posts 4 and 6? lol
You are wrong my friend. Glass houses.
My statement to the OP: Search! not even once. Pointing out the fact that he did not think before he asked.
This statement was separated by several breaks from the following of: S197 have yall gone soft?
Pointing out the fact the everyone has yet to remove the OP's head. Then run through the village with it on a pole! Just the opposite has happened. A slight mention of the search and it's bound full treasures, then actually giving helpful information.
Get it? :evillaugh:
Easy bud. You are getting a kings portion of grace here tonight.
To answer your questions there are at least 10 Detailed threads on builds of this nature. Rotating assembly, good hard wear, and a good tuner are the big points in all builds.
