Turbo spec Cams naturally aspirated??
race4food
Baton Rouge
Back in the pushrod days a boosted cal profile worked well for decent power gains and kept good drivability due to the overlap.
Anyone have actual experience with them in the coyote arena?
There is a set of turbo cams locally for a very, very cheap price.
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
What exactly are your goals? Most aftermarket cams require locking out the phasers and thus only have gains in the high RPM range due to the lack of variable cam timing.
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
Not coyote experience, just my :2cents:,
To a point, I agree with Richard Holdener in that any cam can be a turbo cam.
I haven't followed what tuners are doing with the VCT on Coyotes but in theory, you could manipulate the LSA (well, whatever the equivalent for an independently controlled DOHC would be called-maybe "phasing") between the intake and exhaust cam to spool the turbo quicker or slower and then optimize it at higher RPM's to keep the power band going.
With most modern boost controllers, you can change your boost curve to suit just about any camshaft so the need for a specific type of cam isn't that necessary with independently variable cam timing.
What lift/duration numbers do the cams have?
JEWC_Motorsports
S197 Junkie
Texas
In the coyote world NSR cams are going to be the best thing for a NA car. There are a couple people who design awesome cams. L&M Engines, Mike is a genius and Todd Warren @ ToddWarrenCams.
race4food
Baton Rouge
intake cam lift .513 duration @.50 230 adv:269 Lobe sep 130
exhaust cam lift .500 duration @.50 226 adv:264 Lobe sep 136
these are 1/2 the price of new.
