rzaenglein
As we all know with the 3 Valves, once you put certain stiffer valve spring on our cars you can get noise from the cam phasers unless you have the lockouts. I'm really trying to stay with the limiters because I want to keep the broader power band. I spoke with livernois today and they explained to me Ford has revised these phaser several times. They went on to tell me with Fords newest revision, known to them, that it has been updated with a lighter internal spring and lighter weight material. Livernois said they tested this unit with aftermarket springs. They found that as long as oil pressure stayed at 12psi or higher at the cylinder heads no noise came about with these revised phasers from ford.
New revised phaser part # ends in "HA"
Anyone have more info on this or have this fix their "phaser noise"?
