05stroker
Never enough power guy!
Wich are the best and how hard are they to swap on a 3v head? Also what are the diference between the diferent guides?
Yea ,I would have a mach shop do it but I was wondering , are they just pressed in?That's machine shop work. Silicone bronze works fairly well and lives quite a while.
How much for a set of 24 bronze valve guides Mike?
Mike If you have the bronze guides and they have had liners installed "correctly" are there any advantages of replaceing the guides vrs the liners?Silicon Bronze and Mangenese Bronze are two popular choices. We prefer to use bronze guides because they offer better heat transfer and the ability to run tighter clearances. They tend to offer great wear resistance too.
When doing a full guide replacment it is very important that the correct procedures and steps be taken. Making sure to get the old guides out without damaging the guide bores is critical. Then re-installation of the new guides is another area where maintaining the correct geometry in relation to the valveseat is very important. Any small errors in these processes can yield a damaged or unusable product.
If done correctly though bronze guides offer performance advantages over stock guides in most all situations.
Thanks
Mike
+1 that and the ( stock size ) ss valves themselves too
Hmmmmmm........Mike If you have the bronze guides and they have had liners installed "correctly" are there any advantages of replaceing the guides vrs the liners?
Bronze guide with a liner.So then are you talking having a bronze guide with a liner in it or a bronze guide versus a liner in a stock powdered metal guide?
Just trying to make sure I am thinking the right thing here.
Thanks
Mike
Hey Mike, what is your take on the oversized valves and iron guides? I have this combo and might have a sticking valve.
