VMP 2011+ 5.0L TVS SuperChargers Sale
-Free Shipping & 0% Financing for up to 1 year!
-Stage 1, 2, & 3 kits available!
-If your interested in picking one up please feel free to contact me at 408/898-4632 or [email protected]
Description
When we introduced the VMP TVS 2.3L supercharger for the 2011+ GT and Boss 302, we knew we'd struck gold! Now, the Mustang GT 5.0 and Boss 302 owner can enjoy the benefits of lighter weight coupled with the neck snapping torque of the VMP TVS.
And to give even MORE enthusiasts a chance to grab the brass ring, VMP Tuning has developed a TVS upgrade kit for every budget, starting at just $5999 INCLUDING THE WORLD FAMOUS VMP CUSTOM CALIBRATIONS by JUSTIN STARKEY, loaded and ready to rock on a new SCT X3 handheld device. That's right, a Genuine VMP TVS kit with everything you need, PLUS the tuner and tunes for $5999 for our new Stage 1.
STAGE 1 kit includes:
-VMP 2.3L TVS w/ CNC Ported Inlet & CNC Matched High Flow Inlet Elbow
-High efficiency Heat Exchanger
-47# Fuel Injectors and high-flow fuel rail (Supports ~500-600HP
-JLT 123mm Plastic CAI for Supercharged 5.0L (Carbon Fiber Optional Upgrade)
-Dual 60mm Throttle Body (upgradeable)
-Your choice of pulley size (see below)
-Plug and play wiring harness extensions
-Upper and lower aluminum intake manifolds with high-efficiency intercooler
-Intercooler pump & lines
-1st shiv HD belt system with tensioner, belt, and idlers.
-All required fasteners, wiring, brackets, hoses and clamps
-SCT X3 handheld tuning device and VMP Custom Calibration by Justin Starkey
Features
-Performance – 600+ RWHP 5.0L and 700+ RWHP Boss 302
-Reliability – 1 year warranty and 100,000 Mile Service Interval on TVS blower
-Flexibility – Dial in at a level appropriate for you with our selection of pulleys & upgrades
-Driveability – Fantastic driveability even at the highest boost levels.
-Expandability - TONS of room to grow with many of our optional upgrades
Available Pulley Sizes
-85mm - 9psi
-82mm – 10psi
-79mm – 11-12psi - (72# Injectors minimum requirement at this level)
-75mm – 13psi - (72# Injectors minimum requirement at this level)
-72mm – 14psi - (72# Injectors minimum requirement at this level)
-69mm – 15psi - (72# Injectors minimum requirement at this level)
-66mm - 16psi - (8-rib conversion required)
-63mm - 17psi - (8-rib conversion required)
Dyno Results
VMP TVS with 82mm Pulley, Injector Dynamics 72# Injectors, JLT 123mm Intake, & VMP Heat Exchanger on 93 Octane Pump Gas
VMP TVS with 63mm pulley, 8 Rib Conversion, ID725, VMP Fuel Pump Booster, Cobra Jet 65mm Throttle Body, Dynatech Long Tubes, & VMP Heat Exchanger
Description
Features
-85mm - 9psi
-82mm – 10psi
Dyno Results
