I'm chasing two thing: A supposed vac leak and KR issues.
I can't find ANYTHING re. the vac leak. but, the fuel trims are wacky, out by like 13%. Can't figure it out. I've propaned every connection, redone the BOV piping, taken off the powered side of the PCV and plugged the mani port. No cure. Next is t bolts between the MAF and TB and checking the TB. I can't believe its injector seals, as they looked great and seated properly going in.
On top of that I have heavy KR action, the car will barely take 10 degrees before it starts pulling timing. I've been told on stock Vortech pulley, stock airbox, etc. I should be able to see 17 degrees. That one's the real mystery. No misfire events at all, even on these used stock plugs, gapped .035. The car`s a real dog at 10 degrees, I assure you.
I suggested maybe we go at this from the other side. Put in the timing to what is expected, I'll give it a quick jab and if it rattles, we have a real problem and not ghost knock or something.
Any ideas on either of these appreciated. It's making me and my tuner crazy.
