dysan
Dis-Member
I guess i need to start looking for some pistons! If you know where to find the cheapest,shoot me a link!
Just an fyi, you can use 2v/4v pistons in our engines and depending on your cams you may not even have to cut an exhaust valve relief in them. Hopefully I won't and my new pistons will be Manley flat tops which should have my new build at approx 11:1 compression with my stroker crank.
