irishpwr46
Official Site Vandal
I am looking for some info on wall mount brackets for my bedroom. I want to mount a tv that's around 40". the issue I have is that its going to have to swing out 90° to be visible from the bed. Another issue is that I am going to be mounting it to a double stud, not a 16" spread. my bedroom is not square, and its kinda small. ill try and draw it with regular keyboard characters because apparently I don't have paint on this laptop.
The dresser opposite the bed has a mirror that goes almost to the ceiling.
The R represents a steam radiator.
The D represents another dresser
The C is a closet, next to the closet is the door
The X is where I want to mount the TV, up high so the heat from the radiator wont affect it. I want it to turn flat against the wall facing the closet when its not in use and turn 90° so I can see it from bed.
The corner I want to mount it on has two 2x3 OLD wood studs inside the wall butted up against each other. I emphasize old because they are old growth, close to 100 years old and are strong as hell.
____________________________
l C.... DRESSER With MIRROR.... R l
l C.......................................... R l
l .............................................X l_____
l ......................................................D l
l ......................................................D l W
l ......................................................D l I
l .........................................................l N
l .........................................................l D
l .........................................................l O
l .........................................................l W
l .........................................................l S
l ..............................................._____ l
l ...............................................l
l .....BED AGAINST THIS WALL..... l
l___________________________.l
I am not looking to break the bank here, and I don't care if it isn't an attractive mount since it will not be visible 90% of the time. Any info is greatly appreciated.
