Water got into the intake manifold
MrClean
Marc; but I go by MrClean
Friendswood, TX
Anyone got a pic of the inside 5.4L GT500 intake manifold? I had to pull off the intercooler manifold to remove a broken Metco Aux Idler bracket bolt, and some coolant got into the manifold. Removed the plugs and spun the motor and got the water out of the two rear cylinders (since the motor sits at an incline the water flowed back).
Started up and drove fine, but I want to stay off the boost/high RPM until I'm sure any remaining water has evaporated. I want to see what the inside of the intake manifold looks like so I can determine if there could still be some coolant pooled in there or not.
Thanks!
router
Pro Dyno Racing
Hickory NC
Should be fine, We had a intercooler leak/ bust on ours and its OK now. Did foul plugs 2-3 times.
