Well I'm pulling the trigger too lol
circusboy
New short block is coming next month
1996 Teskid block
2004 Cobra crank
2004 cobra rods
2004 cobra pistons
cobra oil pump (with coated gears)
All ARP bolts (inside and out)
Should handle all the boost i can throw at it with me single 67mm :popcorneat:
I'm probably just gonna run 15 PSI for now. I have a 4R70W I'm gona start building next. Then we gonna turn the boost all the way up :evillaugh:
circusboy
This is gonna be good!
you'll almost be as fast as ME >:)
You need to change your sig lol. I hope it still puts it to the ground lol. Gonna run the auto for the first time this friday, before the cams go in
chad05gt
Lake Charles, La
Schweet! NPR or SCR? I may be able to make a pass in town.
Itll be fun finding out, hopefully with minimal down time(s) LOL!
I think I have 2 of everything(ish)... :wt: hope it gets me through the summer... :beerdrink:
circusboy
We are going to the NPR. Spoken in best IGOR voive, "I have been called out by MASTER". It's gonna be a good one.
kenneth
Louisiana
let's see if this becomes another "freaknazty" lets build it than sell everything.
Good luck, I'll meet you'll at the track soon.
ROUSH1711
UNDER CONSTRUCTION
DE
Those pistons are cut for a 4v head.
circusboy
No sir, She's here for awhile. I got too much money in her to ser her lol.
Freaknazty
KEYBOARD NINJA
SOUTH LOUISIANA
If you only knew lol . Yep I ditched mine last week picked up a new tow rig , now I just need a few minutes to mess with the damn cobra . Frickin house is killing me :handjob:
Mine is for sale in houma now if anyone wants it lmao .
circusboy
I'm not sure. I'll have to find out. Probably the one that came off the 04
circusboy
circusboy
I'm gonna use full lockouts. Thanks for the heads up. Got a templet for the motor mounts and we are going to drill the block for the other passage.
I'll have to check into the knock sensor issue, but I'm using a good shop, so I should have everything covered :beerdrink:
