You must have the 11-14 uca bracket to use the corresponding uca. It relocates the mounting point 1” forward.
The stock 05-09 uca is 8.5” long from cl-cl of the bolt holes. The 11-14 uca is 9.5” from cl-cl of the bolt holes. The newer(longer) uca and bracket are a direct replacement for the older(shorter) version. Doesn’t change static pinion angle at all. Reduces the amount of change as the power comes on.
I know I’m not explaining this very well. I’ll try to put some info together for you.
This picture should explain it pretty well.
They're both BMR upper control arms with their respective brackets.
The '11-'14 unit on the left, the earlier-cars unit on the right.
You get a longer arm but same mounting point because the bracket is different
