RedMosesSC
As some of you may have seen ive purchased an 06 Saleen S281 SC, as you know the Saleen comes with some suspension upgrades:
-Springs
-Shock/Struts
-Front Sway Bar
Now ive done a ton of suspension work on my GT and i want to cary over some of the parts:
-Steeda Lower control arms (fixed)
-Steeda adj Upper control arm w/ heavy duty mount
-Panhard Brace
Im not sure what to do with the sway bars, i have Steeda front(adj) and rear sway bars with the billet mounts. Should i transfer the sway bars over to the Saleen? I understand the Saleen sway bar is solid and non adj but the Steeda piece is hollow, so lighter and can be adjusted and has the billet mounts. The rear sway bar is stock GT on the Saleen, the steeda rear would be lighter and will have billet mounts. Any thoughts? reasons to leave as is or move over?
I will leave the Steeda Springs & D-specs on the GT, i dont think its worth the time to remove the camber plates because id have to get new set as they are one time use. I dont want to spend money on the alignmet, so its not worth removing the adj tie rods or Ball Joints.
Anything i may be forgetting? Any thoughts?
Thank guys!
-Springs
-Shock/Struts
-Front Sway Bar
-Panhard Brace
Thank guys!
