What torque converter?
2010S197
I drive 2010 gt, 5r55. The car dead hooks out of the hole either leaving from idle or power brake @ 2k rpm. I’m thinking the stock converter is holding me back. Is the TCI 3000 rpm stall sufficient for a low power na build. Or do I drop the bid bucks on a circle D ( they recommend a 3500 stall). Also is the hardened input shaft needed for my build, no plans for a power added. Goal is solid and repeatable 12s. Currently car is very consistent 1.9 60’, 13.0-13.2, DA has been 3000-3900 ft this summer with the heat and humidity.
Mods are as follows
Upd
08 intake with CMDP
4.10 steeda
ET streets on 16” v6 wheels
Brenspeed 93 tune
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
With mild mods, I'd contact some of the converter companies to see if they can re-work a stock converter.
Circle D offered this a few years back.
GERMANSHEPERD
Ohio
Bolt-ons, Comp Stage 2 cams, ported heads on a 281 a TCI 3000 put Me 12.11 back in 2009 when I ran at E-Town.
TCI 3000 is a great bolt-on street converter that almost put me in the 11s in NJ and 12.2-12.3 here in Ohio.
Hawgman
THE fucking bad guy
Texas
You might also consider a Precision Industries converter. I have a PI Stallion triple disk 3800 stall converter in my car and love it. Granted, my build is considerably different from yours. But their converters are great
2010S197
from all my searching online it seems PI or. Circle D are the best choices. I miss the days of active vehicle specific forums FB and social media group pages are a poor replacement.
07 Boss
Sin City
Great choices I have a PI triple disc, but I'm not sure you need to spend the cash on one of those at your power levels. For half the price you can get one that works well. TCI is not my first choice but for basically a stockish type unit I wouldn't hesitate to use them. For a car that is mainly street driven with a few passes a year I would choose my stall speed to about 500 rpm's below your peak torque rpm.
jam07GT
When factoring in DA and you running a 93 tune and I run a 91 tune, we run pretty similar times (my mph is 84.6 in 5000 DA). From what I have read the stock converter is a weak link and the input shaft. I have the TCI 3000 and hardened input shaft. It worked fine, before my trans started slipping or whatever. But if I were you I'd go 4k. An NA car needs converter. What's the difference between 3K and 4k, really. It's going to be soft anyway when you are just driving around town, which is usually below 3k and the converter locks up on the interstate. We both run 1.9 60s, and I think it's hard to get lower than that without a higher stall speed when you have as little power as we do.
My 5r55s started slipping after about 40 1/8 mile runs or so. At first it would snap your neck on every shift, then it got softer and softer, and my times went from 8.42 to 8.6x, to 8.8x etc. and once in a while the transmission light will come on and DTC P0745 (pressure control solenoid A circuit malfunction). Changed the fluid and all that, and it made no difference.
Anyway, that's my experience with this transmission. I daily drive my car now, not racing it, and it runs fine just cruising around, and I haven't gotten the code in awhile but it will pop up from time to time.
2010S197
With the TCI converter it looks like I need to retain the rocket 8 lug to 4 lug adapter ring. Is this a paint to get properly lined up?
2010S197
So did you ever have the trans rebuilt or you just drive it as is with no racing? how many miles were on it when it started to slip
