Wheels - 2010 GT Premium 19x10
tjm73
of Omicron Persei 8
Rush, NY
I have admired these wheels for a long time. I see they are 19x10 with 48mm offset and you list them as rear only. I know some guys run 18x10 with 45mm offset on all four corners without issue.
Is there a physical reason this wheel does not fit the front? Does the center hit the dust cap or something?
I suspect it should fit.
Thanks.
AMChrisRose
AmericanMuscle.com
Malvern, PA
Good question! Let me find out first thing tomorrow for you. Our wheel team has probably test-fitted them to see whether or not they would fit front wheels. There SHOULDN'T be a physical reason they don't, but let me make sure. Just to be 100% clear, what year/model is it going on? And if it's a newer model, standard brakes or Brembo package?
Let me know and I'll find out for you right away!
Chris
tjm73
of Omicron Persei 8
Rush, NY
2011 or 2012 GT standard brakes. I'm just starting to search for what I want and I really am liking these wheels...A LOT.
tjm73
of Omicron Persei 8
Rush, NY
AM's site said the 18x10 AMRs wouldnt fit on the front and mine fit perfectly.
Exactly the kind of thing that sparked my curiosity. :boobies:
I'm thinking some 285/35R19's would look pretty sweet on them.
AMChrisRose
AmericanMuscle.com
Malvern, PA
So, the 18x10's that mikeyfitz is running on the front of his 11+ with standard brakes are +48mm offset. You're looking at a 19x10 with the same offset. There's no physical reason it shouldn't work. It should be identical, just an inch bigger.
Let me just get a final opinion on that one, though. As always, if we send them to you and they don't fit, just put them right back in the box in new condition and we'll pick them back up from you!
I think we're good to go, though. I'll confirm today!
Thanks
Chris
tjm73
of Omicron Persei 8
Rush, NY
I figured as much. Might be looking to talk seriously in the spring.....
mikeyfitz
Resident Fuktard
Houston, TX
It should work, I run 285/40s on all 4 corners and I dont even come close to rubbing anything. Dropped on K Springs as well
tjm73
of Omicron Persei 8
Rush, NY
Any pics looking down the side of the car showing wheel placement in relation to the body?
mikeyfitz
Resident Fuktard
Houston, TX
Went to get tires rebalanced and remembered haha.
tjm73
of Omicron Persei 8
Rush, NY
Wow that is right at the limit in my opinion. Looks great too.
Thanks for the pics. Just what I was looking for.
AMDanBailer
AmericanMuscle.com
Malvern, PA
Hey,
I heard back from my Install team and they don't recommend 19x10's on all 4 corners. It will most likely fit under the fenders without any problems, but they will stick out an additional 18mm from the 9s. However the above picture in my opinion look perfect, so this decision is up to you!
I hope this helps, let me know if you have any further questions!
-Dan
