well got the swaybars on. i set the front on the 3rd hole and rear in the fourth and will see how goes and change from there.
the whiteline front bar is pretty heavy but i like the solid swaybar and the design of the rear is tits to me. i just couldnt figure out how to "set-up" the rear as far as the endlinks. didnt know if the end where the links hook to it needs to be parallel with the ground or if it should have an upward tilt to it at the end.
Doesn't matter, as long as both end links are the same length. (Unless the car is corner-balanced.)
Sent from my toilet using Tapatalk
