will it work
peetiewonder
Terminator
SFV, CA
you can make it work. don't plan on putting anything larger than a 275 on that 10.5 though.
peetiewonder
Terminator
SFV, CA
The rears need to be at least +45 to prevent the tires from sticking out of the body.
...unless you run a 275
Yes you can make it work.....but the wheels will sit outside the fender depending on the tire size.....I woul recommend a 285+ on the rear.
285 + will make the tire sit outside the fender.
how far outside ? 10 mm ?
depends on the tire size. the wheels themself will probably sit about 5mm beyond the fender, but with a 275 the tread should still be inside the fender.
donatiohseven
i mean id like for them to be semi meaty. but not rub. with the 35 offset i should be clear from rubbing on the strut but its also a 10.5 inch wheel .... so i dont want to rub outside either ! this is so hard !
