will taller front tire help times?
beefcake
Forced Induction Specialist
Official Vendor
Bethel, Ohio
curious, the tires i have up front now are about 24.5 to 25 inches.
m&h makes a 27 and a 28" tall tire, i'm running a 28" tall tire in the rear.
i'm wondering if launch and going down the track if that would be better with the taller tire. i'm thinking after talkin to a buddy today, that it does make sense as the weight transfer outta be better and it won't nose over as bad
TotoGT06
SE Wisconsin
Im curious about this too but Im wondering how it would be if the front is a bit higher than the rear if that affects anything also because im running stock tires and wheels up front and then 275/50/15s in the rear
don_w
Dyno Numbers - Who Cares?
San Diego, CA
A taller front tire will also increase rollout at the starting line, which will trigger the beams a tick later and decrease ET.
rojizostang
i love my cams
san antonio, texas
i thought a taller tire would get the nose up in the air and help weight transfer...which would lead to improved et's
