Windshield wipers motor stripped?
Ed Brown
Motor works fine but wipers dont work, they move a little if you move them and grind real bad sometimes when you try to get them to move. I just wondering if I buy new motor how yo phrase the wipers if its spun.
DieHarder
?? Are you sure something is not damaged or loose? If motor is moving check the wiper frames for damage.
As far as indexing goes: The wiper motor automatically stops at a preset point which is at the bottom of the stroke (windshield wipers will be at the bottom of the windshield. The motor should already be indexed correctly. If you're worried about indexing the wiper arms wrong connect the harness into the motor (before connecting into the wiper frame) and turn the wipers on, then off. It'll do a cycle and then stop. Then install it into the frame. Then put your wipers on.
86GT351
Sunny South Florida
This
